Online Now [1021]:
Visitors: 1020
Today: 188802
Total: 155278512
Forums › The Car › Request a how-to › Light Masking
Light Masking
TomRobbo94
PostPosted: Fri Jul 26, 2013 7:34 am Reply with quote Up
I think its called painting where the inside of the light is painted?
Peugeot 206 1.1 Smile Best car in the world... so far Wink
Paddy1795
PostPosted: Fri Jul 26, 2013 8:00 am Reply with quote Up
This is the how to on here but the pictures don't work, could probably get a good idea from the instructions though!
www.206info.co.uk/Foru...=5989.html
Paddy1795
PostPosted: Fri Jul 26, 2013 8:03 am Reply with quote Up
Just found this too, a pretty decent tutorial, although not a 206 I'm sure its pretty much the same.
forums.mightycarmods.c...headlights
TomRobbo94
PostPosted: Fri Jul 26, 2013 8:05 am Reply with quote Up
Spot on buddy cheers Smile
Paddy1795
PostPosted: Fri Jul 26, 2013 8:13 am Reply with quote Up
No bother mate! I'm tempted to give it a shot now!
TomRobbo94
PostPosted: Fri Jul 26, 2013 8:28 am Reply with quote Up
Same defo a job to be done this weekend with this weather Razz
Paddy1795
PostPosted: Fri Jul 26, 2013 8:32 am Reply with quote Up
Agreed! Only problem I've heard about masking them is that because you've broken the seal around the light then they can start to let water in :/ Mine do that anyway though so it doesn't matter haha!
TomRobbo94
PostPosted: Fri Jul 26, 2013 8:35 am Reply with quote Up
hmmm might put mastic round the seal when i do it to reseal it as such
Paddy1795
PostPosted: Fri Jul 26, 2013 8:39 am Reply with quote Up
Yeah that sounds a good idea, I was thinking about just sealing it up with some sort of epoxy haha.
TomRobbo94
PostPosted: Fri Jul 26, 2013 8:57 am Reply with quote Up
Same difference lol
PostPosted: Fri Jul 26, 2013 9:07 am Reply with quote Up
I did mine last weekend. Used the heat gun method. Found with the second one after heating and lifting the tabs, started at the indicator corner and just heated both sides gently while easing apart. The biggest ball ache was removing the old sealant to get a good clean surface fr the new stuff to stick to.
Paddy1795
PostPosted: Fri Jul 26, 2013 9:12 am Reply with quote Up
Nice one! They look good!
TomRobbo94
PostPosted: Fri Jul 26, 2013 9:55 am Reply with quote Up
Whats the heat gun method?
PostPosted: Fri Jul 26, 2013 10:18 am Reply with quote Up
Heat the plastic tabs gently and lift off the lens lug. Then just heat along the join to soften the glue. The oven method is to put the entire assembly into an oven and you can soften the tabs and glue at the same time. No idea what temp you'll need to set the oven on, felt there was more heat control with the gun. Last thing you want is the Mrs to go put the beef in the oven on Sunday only to find a big lump of molten plastic in the bottom of it.
TomRobbo94
PostPosted: Fri Jul 26, 2013 10:28 am Reply with quote Up
OOOOH your talking about resealing it?
  Quick Reply
Username:
Message:
Quote the last message
