Latest: DanDan17
Overall: 17128
Online Now [200]:
Visitors: 199
Today: 38442
Total: 100599110
Forums › The Car › 206 Talk › PDR on rear quarter panel
Andrew
PostPosted: Sun Jul 28, 2013 3:36 pm Up
Hi guys
My car picked up a ding from a Range Rover Discovery - second dent to happen from one of these cars. It's only small but anyone who knows me will understand what I'm like. Sadly its on the rear quarter panel, an inch below the glass and a couple inches away from the door. I have a contact who is a pro at paintless dent repair but I'd like to know if it is possible on this panel as I've heard it is double skinned.
Thanks for any insight
My 206 thread
www.detailedbyandrew.com
Lecktorious
PostPosted: Sun Jul 28, 2013 4:24 pm Up
Trade Rating: +59
You should be able to get in at it if you take the rear door card off mate. Knock the area with your knuckle and if it sounds hollow, a PDR guy *should* be able to get their tools in there.
'98 Nile Blue 306 GTi 6
Andrew
PostPosted: Sun Jul 28, 2013 5:29 pm Up
Cheers G Smile Is it dificult to remove that card? I've never had to remove it before
My 206 thread
Lecktorious
PostPosted: Sun Jul 28, 2013 5:39 pm Up
Trade Rating: +59
Nah it's straight forward enough. You just need to move the doorcard out the way, so I wouldn't worry too much about unbolting the seatbelt and removing it completely.
Ryry238
PostPosted: Mon Jul 29, 2013 6:34 am Up
To remove the rear door card its pretty easy Iv just done both of mine (on 3door) to change the speakers.
Just unbolt the 15mm anchor bolt for the seat belt, remove the door seal and it should just pull off with clips still in might take a good pull
Uz
PostPosted: Mon Jul 29, 2013 7:26 am Up
Theyll be able to do it without removing the interior Andrew. I've had mine looked at and he'd have been able to do it just by work from the outside.
Andrew
PostPosted: Mon Jul 29, 2013 11:45 am Up
Thanks guys, I pulled the card back and found that the area seems to be workable from the, so at least the chances of it being successfully repaired are increased
My 206 thread
PostPosted: Mon Jul 29, 2013 11:52 am Up
How bad is it? Or is it just because you've had that part repainted?
Andrew
PostPosted: Mon Jul 29, 2013 12:04 pm Up
Range rovers have horrible corners on their doors so its a proper dint, I'm happy to find it is accessible though
The fact that it has been painted shouldn't affect things hopefuly, because its paint on metal
My 206 thread
