Posted: Sun Jul 28, 2013 3:56 pm |
Hi guys another one for you.
The fuel lift pump doesn't seem to work. I've lifted the sea and there's no noise.
Which wires in the plug are for the pump?
I have 3 wires on the multiplying but 4connectors on socket on the top of the pump assy.
Is there a cut off switch anywhere?
Does it have a relay.
All the fuses in both boxes are ok.
Is it the wrong pump fitted?
A lot of questions sorry. I bought a Haynes manual but it doesn't cover the 1.6 110 hdi.
Thanks in advance
Posted: Sun Jul 28, 2013 3:58 pm |
Easiest way to tell is disconnect a pipe at the engine and see if it pumps
Whats the fault with the car?
| Team Impossible Possible
Posted: Sun Jul 28, 2013 3:59 pm |
Doesn't pump. I've tried that. The car won't start at all
Posted: Sun Jul 28, 2013 4:00 pm |
Sorry it starts briefly then cuts out as its starving of fuel
Posted: Sun Jul 28, 2013 4:09 pm |
If it starts you know its working, as if im right the pump runs minues pressure and uses vacuum to the high pressure pump but i can be wrong! As my minds blank atm
Fault codes? Parameters? Any more info
Posted: Sun Jul 28, 2013 5:07 pm |
No fault codes stored. As far as I'm aware the lift pump works on pressure rather than vacuum.
Posted: Sun Jul 28, 2013 11:16 pm |
All HDi engines work on the High Fuel Pressure,so in your case you have 3 options:
1-The High Fuel Pressure sensor located on top of the fuel Pump is faulty.
2-The High Fuel Pressure Sensor located in the engine bay close to the (Common Rail Bump) is faulty.
3-The Common Rail Bump itself is faulty,as long your lift pump is working,so you might have inner failure when it get warm.
Posted: Mon Jul 29, 2013 5:25 am |
Thanks ill have a look when I finish work
