Latest: DanDan17
Overall: 17128
Online Now [63]:
Visitors: 62
Today: 8039
Total: 100527994
Forums › The Car › 206 Talk › engine bay paint
engine bay paint
ryanovsalford
PostPosted: Tue Jul 30, 2013 5:49 am Up
hi huys was just thinking about freshening up my bay and i know i require high temp paint for my rocker cover and mai cover but want to give the plastics a fresh lick of paint battery box fuse box etc . would standard prime paint and laquar be sufficiant of wound the heat in the bay just kill it??
frenchfrog40
PostPosted: Tue Jul 30, 2013 5:53 am Up
iv used halfords own primer, paint and lacquer for my rocker, battery and fuse covers. They would have all been fine but i put the rocker cover on while it was still a bit wet and the paint cracked. battery and fuse cover are both fine though
Iv had:
ryanovsalford
PostPosted: Tue Jul 30, 2013 6:51 am Up
you used standard paint on your rocker take it it isnt a 8v then but everywhere else the paint is ok just let it cure properly before puting the bits back on
dafdavies
PostPosted: Tue Jul 30, 2013 12:40 pm Up
I've got normal paint primer on my 8v rocker cover been fine since I done it
Team: If you cant find the tool you need make one
frenchfrog40
PostPosted: Thu Aug 01, 2013 3:40 am Up
no mines 16v. its the 2nd time i did rocker cover, was fine first time because i let it dry. was impatient this time as FCS was coming up so it was still a little wet when i put it on
Iv had:
hayes_ctfc
PostPosted: Thu Aug 01, 2013 8:22 am Up
I used Halfords paint on my Air box, Battery cover and fusebox cover and they've held strong, but it has come away a bit on the airbox as I've got a bonnet bra on and it's stuck on to that which is a pain
OLD: Peugeot 206 2.0 GTi 138
NEW: Seat Leon FR TDi 170
