Latest: DanDan17
Overall: 17128
Online Now [196]:
Visitors: 195
Today: 2878
Total: 100603304
Forums › The Car › 206 Problems › Front ARB D Bushes
Front ARB D Bushes
Mike_XS
PostPosted: Sat Aug 03, 2013 2:08 am Up
I am replacing the D bushes on the 206, only when I went to order them I was told they will either be 18 or 19mm.
Does anybody know off the top of their head what they will be on my 2000 1.6 xs?
Cheers Smile
PostPosted: Sat Aug 03, 2013 4:37 am Up
Check on servicebox to see which anti-roll bar is fitted. I've just looked at the TU5 and it lists 19mm and 20mm depending on the build code. Ideally needs to be checked using the VIN.
If you don't have servicebox, PM me your VIN and I'll check for you.
Mike_XS
PostPosted: Sat Aug 03, 2013 8:54 am Up
I managed to get hold of some vernier gauges in the end, mine is 19mm. Thanks anyway! Smile
wifes206
PostPosted: Sat Aug 03, 2013 9:04 am Up
Where did you measure it?
Next to where bushes fit
Or under where bushes fit on the two flat bits from flat to flat?
Mine is 21.5 thought was 20.5 but just checked again
And flat to flat under bush is 17mm
So I'm none the wiser as to what bushes to get
206 2.0hdi(04)
Mike_XS
PostPosted: Sat Aug 03, 2013 9:08 am Up
Measured it 3 or 4 inches away from the bushes.
wifes206
PostPosted: Sat Aug 03, 2013 9:12 am Up
Looks like I'll have to get the vin on here to get
some help
206 2.0hdi(04)
Mike_XS
PostPosted: Sat Aug 03, 2013 9:14 am Up
I was told by my local car parts dealer that they only do 18 or 19mm bushes. It's strange you are getting a .5mm measurement...
