Latest: sparrowdclxvi
Overall: 17139
Online Now [149]:
Visitors: 148
Today: 28489
Total: 113476636
Forums › The Car › 206 Problems › Clocks not working?
Clocks not working?
seanbrown121
PostPosted: Sun Aug 04, 2013 8:59 am Up
i drove to asda earlier and everything was fine, as i finished shopping got in the car to drive off and the speed, revs, fuel, oil temp or water temp dont wwere not working?
The headlight light was on and the indicators were ok ? but just the actual needles were all sticking flat? never done it before , any ideas? are they all on a fuse somewhere?
tommyb32
PostPosted: Sun Aug 04, 2013 1:16 pm Up
maybe try a bsi reboot?
put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
Failure to follow this procedure could result in incorrect operation of many BSI related items.
Steve137
PostPosted: Mon Aug 05, 2013 12:59 pm Up
i had this problem mate and i changed the fuse but cant remember what one it was sorry
