Latest: sparrowdclxvi
Overall: 17139
Online Now [517]:
Visitors: 517
Today: 67995
Total: 112751936
Forums › The Car › 206 Problems › 2.0 HDi Boost Controller/ Boost Gauge?
seanbrown121
PostPosted: Sun Aug 04, 2013 7:31 pm Up
Hi
Where exactly do i T-piece into the vacuum pipes to fit a boost controller and a boost gauge?
to the back of the engine there is an actuator going to a soleniod, the pipe that joins them, would that be an appropriate place ?
Cheers
PostPosted: Mon Aug 05, 2013 12:56 am Up
Manual boost controllers are the devils work. And I strongly recommend avoiding the temptation.
For the boost pickup for a gauge. Use some where close too or off the inlet manifold, or worst case just off the boost pipes after intercooling
seanbrown121
PostPosted: Mon Aug 05, 2013 6:00 am Up
So how do you control the boost if you don't use a manual boost controller ?
PostPosted: Mon Aug 05, 2013 1:03 pm Up
Electronic boost solenoid, that when you remap the car the pressure is increased
