Online Now [586]:
Visitors: 586
Today: 145759
Total: 154017307
Forums › The Car › 206 Problems › Loud retro rattle from Engine 206 1.4 petrol?
Discostu
PostPosted: Wed Aug 07, 2013 4:40 am Up
I was hoping to get some advice / guidance.
I have a loud noise that sounds like its coming from the engine - I can only liken it to the noise I got when I stuck a lollypop stick in the spokes of my BMX (well over 20 years ago Shocked ) The noise disappears when I have my foot on the accelerator or when the car is not in gear - basically it only happens when the car is in gear and my foot is not on the accelerator. Hope that makes sense as I haven't much of a clue when it comes to what's under the bonnet. The car itself drives perfectly normal - aside from pulling to the left!! Any advice is greatly appreciated. Thanks
PostPosted: Wed Aug 07, 2013 5:30 am Up
I have a loud noise that sounds like its coming from the engine - I can only liken it to the noise I got when I stuck a lollypop stick in the spokes of my BMX (well over 20 years ago Shocked ) The noise disappears when I have my foot on the accelerator or when the car is not in gear - basically it only happens when the car is in gear and my foot is not on the accelerator. Hope that makes sense as I haven't much of a clue when it comes to what's under the bonnet. The car itself drives perfectly normal - aside from pulling to the left !! Any advice is greatly appreciated. Thanks
You want to fix that ASAP.
Video/audio would help with the noise problem if you can ..
hush1275
PostPosted: Wed Aug 07, 2013 6:11 am Up
Tappets?
Grand tourisme #1146
wifes206
PostPosted: Wed Aug 07, 2013 6:51 am Up
So when in neutral on tick over there's no noise?
206 2.0hdi(04)
Discostu
PostPosted: Wed Aug 07, 2013 7:20 am Up
Thanks for thwhe replies. There's no noise at all when in neutral, just in gear with foot off the accelerator
anthony_839
PostPosted: Wed Aug 07, 2013 8:52 am Up
sounds like gear box,
what about if your driving and lift off do you still get the same sound
euroed astra
Discostu
PostPosted: Wed Aug 07, 2013 12:56 pm Up
I only get the tattling noise when I have the car in gear and with my foot not on the accelerator. I've taken it out of car mid drive and the sound goes - then selected the appropriate gear, kept my foot of the accelerator and the noise returns. It does drive ok, loud noise apart. Thanks
Discostu
Thats meant to be rattling noise!!
