Online Now [244]:
Visitors: 242
Members: 1
Today: 67911
Total: 156587810
Forums › The Car › 206 Problems › Anti Pollution Fault Gti 180 Error code P0351
Jammie_1989
PostPosted: Wed Aug 07, 2013 7:10 am Up
Cars running rough intermittently and have bought a bluetooth code reader off ebay and its putting out error code P0351 and also P0011 although I'm pretty sure the P0011 relates to when my cambelt was fitten roughly last year.
Have also used the reader to track the voltage of the lambda sensor and it was all over the place. Have booked the car in at the garage tomorrow and hope this is all it is.
Anybody else have experience with other things this would be?
206 gti 180
HDI90
PostPosted: Wed Aug 07, 2013 7:15 am Up
P0011 is a vvt fault that could be causting the rough idle
GTI 180
Hawkers
PostPosted: Wed Aug 07, 2013 7:30 am Up
P0351 - Ignition Coil 1 Primary/Secondary Circuit Malfunction
- Faulty Ignition Coil 1
- Ignition Coil 1 harness is open or shorted
- Ignition Coil 1 circuit poor electrical connection
- Faulty Engine Control Module (ECM)
P0011 - Camshaft Position 'A' Timing Over-Advanced or System Performance Bank 1
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
HDI90
PostPosted: Wed Aug 07, 2013 11:52 am Up
P0011 on a 206 gti 180 is the vvt locked at upper stop. in other words its f****d
GTI 180
Jammie_1989
PostPosted: Wed Aug 07, 2013 1:10 pm Up
Surely if the VVT was a problem then it would run s**t all the time. I'm pretty certain the only problem with the car is the P0351 code as that is what is most likely linked to the anti pollution fault. It also only runs rough when the antipollution fault comes on when driving. Will see what the garage says tomorrow. Car is turning into a money pit might be time to get rid.
206 gti 180
Leegsi
PostPosted: Wed Aug 07, 2013 1:14 pm Up
Clear the codes and see what one comes back
Ali_H
PostPosted: Wed Aug 07, 2013 1:34 pm Up
I had P0011 on mine a couple of years back, changed the VVT Solenoid and never had any problems since. About £70-80 IIRC.
Have you had the cambelt changed?
kurtis wrote:
Jammie_1989
PostPosted: Wed Aug 07, 2013 6:44 pm Up
I cleared the codes and only the P0351 came back. I also did a volt test on the lambda sensor and most the time it was showing 0 then every now and again went to 0.1 so i think that might be the problem. I don't think its the cat which it apparently can be as you can smell it working at the exhaust.
It could be the coil pack I suppose although i've seen a lot on google of people with this problem and replacing the coil pack didn't fix it.
206 gti 180
