Online Now [447]:
Visitors: 446
Today: 55837
Total: 156771175
Forums › The Car › 206 Problems › Manual air con blows out cold (Brrr!) but not hot
longshortchris
PostPosted: Fri Aug 09, 2013 11:25 am Up
As the topic states, my manual air con will blow out cold when it is turned on. I'm glad that it is at the moment. Very Happy
But, when I go to work in the morning at 1-2:00 am, it would be great to demist the windscreen. The air con, when turned on & switched to hot, just blows out lukewarm air.
Any ideas, please?
Chris
PostPosted: Fri Aug 09, 2013 2:10 pm Up
Well you will have a problem with the switch that control the Cold/Hot air,or a problem with cable pulling the control valve so switch from cold to hot and hot to cold when needed,to make sure what is the problem is,try to move the swtich,if it feels soft and there is no resistance,then the cable is snapped ,if it's heavy kind of,then u have a faulty switch itself,if neither of these 2 options,then you have a clogged heater matrix.
longshortchris
PostPosted: Fri Aug 09, 2013 2:48 pm Up
I get normal hot/cold air from the heater. That, I didn't make clear. Sorry.
Chris
ARRAN
PostPosted: Sat Aug 10, 2013 4:43 am Up
Why are you trying to demist the window using aircon? :S Just turn the aircon off, and put the heat up all the way..
See my project here.
longshortchris
PostPosted: Sat Aug 10, 2013 4:56 am Up
The air con should be blowing warm with one minute. It's more economical in time & fuel to turn the air con in the morning to demist the windcreen than sitting & waiting for my car (90 HDi) to warm up naturally. Which is rather silly IMHO.
I was hoping I could get some knowledgeable advise before I take it to the garage. I just wanted to know if a re-gas or a condenser replacement would be necessary.
Ah, well...
Chris
2Oh!6
PostPosted: Sat Aug 10, 2013 5:35 am Up
Are you sure?
I thought that's what climate control did. I duno though Laughing
VTEC goes BWAAAAAAH! Wink
PostPosted: Sat Aug 10, 2013 5:53 am Up
You obviously don't understand how air conditioning actually works.
ARRAN
PostPosted: Sat Aug 17, 2013 4:10 am Up
Very true Laughing just I've never used.it to demist and if the OP's aircon isn't demisting his, just wondered why not use a cheaper easier alternative.
longshortchris
PostPosted: Sat Aug 24, 2013 3:08 pm Up
[quote="ARRAN"][quote="MrBSI"]
ARRAN wrote:
...just wondered why not use a cheaper easier alternative.
Err?
The aircon should be blowing warm & demisting my window whilst I'm on my way to work early in the morning. When the engine is warm (I have dials in front of me, do you?) I can then turn the aircon off.
It's a lot faster & economical than keeping the car in the driveway whilst you wait for your block to warm up.
In the winter, I start the engine & turn the aircon onto hot & on recycle. I then scrape off the ice on allof the windows & on my headlights. I get into the car & drive off. Aircon is not just for blowing cold air during an Indian Summer!
I was hoping for some creative & knowledgeable responses rather than the ignorant replies this thread has created.
Anyway, I've now booked it into an independent Citroen/Peugeot specialist who are only two miles down the road.
