Posted: Sun Aug 11, 2013 12:07 pm |
Trade Rating: +13
As above. I have been quoted £262 to supply fit and regass
Can someone please get me the part number from service box?
I will PM you my VIN.
I want to see if I can reduce the bill by buying and fitting it myself as the gas system is currently empty. Ten I just have to pay to have it tested and regassed.
Posted: Sun Aug 11, 2013 12:16 pm |
Since it's you, PM it to me. It will be later on as it's Sunday and servicebox is down at the minute
Posted: Sun Aug 11, 2013 12:25 pm |
Beat you macca! Cant get a price as servicebox is down, as macca mentioned.
Posted: Sun Aug 11, 2013 1:06 pm |
Euro Car Part sell these don't they?
Posted: Sun Aug 11, 2013 1:07 pm |
Trade Rating: +13
Not sure yet I will call the dealers and check cp4less ECP ETC ETC
Posted: Sun Aug 11, 2013 1:11 pm |
Trade Rating: +13
Looks like Valeo one is £66 delivered. Not to bad?
Posted: Sun Aug 11, 2013 1:16 pm |
Check with your dealer, parts have been cheap lately.
Posted: Sun Aug 11, 2013 1:48 pm |
Posted: Sun Aug 11, 2013 1:57 pm |
How did they know which part is at fault? Reason I ask is mine have never worked, tried to get it regassed on Thursday and hey told me they had to stop due to a massive leak. Have you had it uv tested?
Posted: Sun Aug 11, 2013 1:59 pm |
Trade Rating: +13
Cheers guys its 01 I need it has 4 leeks down the right hand seam. The service box prices are funny and scarry!
Posted: Mon Aug 12, 2013 2:42 am |
Might be worth keeping an eye on?
clicky 1
Posted: Mon Aug 12, 2013 6:02 am |
How do you know it's leaking? I would suspect pipes first.
Posted: Mon Aug 12, 2013 6:23 am |
Steve206 wrote: |
How do you know it's leaking? I would suspect pipes first. |
Or the seals that connects from the pipes to the condenser.
Posted: Mon Aug 12, 2013 6:24 am |
Trade Rating: +13
Because it has been to an aircon specialist and pressure tested. I was asked to go into the garage and they showed me with the uv light the 4 leaks down the right hand seam of the condenser.
