Latest: Puggingalong
Overall: 17129
Online Now [39]:
Visitors: 38
Today: 52157
Total: 100721500
Forums › The Car › 206 Problems › Rear end creeking
Rear end creeking
206gti_chris
PostPosted: Sun Aug 11, 2013 1:39 pm Up
Got the old rear end creek, originally thought it was the boot but it definitely isnt, seen a few things about rear axle bearing? ive looked underneath the rear and all the bushes look old and dry
whats worth replacing?
PostPosted: Sun Aug 11, 2013 2:53 pm Up
the whole rear axle would be a good idea Smile
206gti_chris
PostPosted: Sun Aug 11, 2013 3:13 pm Up
yeah suppose only 245 quid lol
206gti_chris
PostPosted: Mon Aug 12, 2013 4:44 pm Up
turns out once i removed the rusted old spare wheel and bracket, and re-ajusted the boot lock position the creek and squeaks stopped.. MAJOR cheap fix
206gti_chris
PostPosted: Sun Aug 18, 2013 2:32 pm Up
Nope... still creeking lasted 1 day then all the creeking again no idea what causes it but it only disapeers when i ajust the boot latch so you have to literally force the boot shut otherwise a light shut wont work.......... Anyone got an answer? only i would use the SEARCH but its absolute shi-t type in boot noise 1800 matches found not one post relevant to a boot.................
206gti_chris
PostPosted: Mon Aug 19, 2013 5:00 am Up
anyone else had this ?
PostPosted: Mon Aug 19, 2013 5:20 am Up
Play in the trailing arm bearings? They can fail whilst the seals still look intact
206gti_chris
PostPosted: Mon Aug 19, 2013 8:31 am Up
how do i check if it is?
PostPosted: Mon Aug 19, 2013 12:00 pm Up
I think you already know from the other post but as follows:-
Jack the car, put on axle sttands and push pull with hands at 12 / 6 o'clock then 9 / 3 o'clock and push, pull, twist and try to see whjere the play is. Is it in the arm bearing or the hub.
