Online Now [558]:
Visitors: 557
Today: 138835
Total: 155433328
Forums › The Car › 206 Problems › Oil leak with video. Clues please
mattymj
PostPosted: Sun Aug 11, 2013 3:38 pm Up
Would anyone know where it maybe coming from?
Video link
PostPosted: Sun Aug 11, 2013 3:44 pm Up
Well it's above the manifold so it's not the head gasket. Looks like either the rocker cover seal or the sealant holding the upper camshaft housing has failed.
PostPosted: Sun Aug 11, 2013 3:52 pm Up
Looks like it's the rocker cover seal have failed as Edward said,try to replace it first,as it's a simple DIY job :),if that didn't fix the problem,well think of other causes,but you need to give it a good clean when you change the seal.
mattymj
PostPosted: Sun Aug 11, 2013 3:54 pm Up
Thanks Edward. Such a hard place to see. It doesn't show any loss on the dipstick
mattymj
PostPosted: Sun Aug 11, 2013 3:55 pm Up
Ok thanks Timon. A good clean up will show if the leak re occurs
