Posted: Mon Aug 12, 2013 5:14 am |
Can the sensor be replaced without taking the driveshaft out?
Posted: Mon Aug 12, 2013 10:14 am |
206HdiGti wrote: |
Can the sensor be replaced without taking the driveshaft out? |
If you mean the ABS sensor, then yes, wheel off and 2 nuts and it will come out. The worst one to do is the front drivers side, not getting the sensor out the hub, but actually getting at the plug.
Posted: Tue Aug 13, 2013 4:18 am |
Think I may have a plug issue
Posted: Thu Nov 14, 2013 4:58 pm |
I have joined this forum due to having just purchased a 206 1.6 gti hdi 110. Got it cheapish because it has the same problem as you have described. Is it a fairly easy fix if you know what you are doing?
Posted: Thu Nov 14, 2013 5:15 pm |
I've left mine as it seemed to go away if I turn the ignition off then back on again lol
