Latest: DanDan17
Overall: 17128
Online Now [112]:
Visitors: 111
Today: 15686
Total: 100413871
Forums › The Car › 206 Problems › GTI 180 ABS pump
GTI 180 ABS pump
Daniel206RC
PostPosted: Mon Aug 12, 2013 1:07 pm Up
Hi!
I'm having trouble with the ABS system!
My abs pump has these numbers:
9650222880
10.0206-0118.4
I bought one on ebay with these numbers:
9649026780
10.0206-0100.4
Is it possible to use this?? or do I have to get one with the same numbers?
I can't remember the fault codes, but it's about the ABS "brain".
03, RC / GTI180
03, SW XSI
PostPosted: Mon Aug 12, 2013 2:01 pm Up
you can do a configuration using PP2000 for the ABS/ESP ECU,so that it make an adoption for the new one,this is what I know,wait for another to confirm.
PostPosted: Mon Aug 12, 2013 3:00 pm Up
What's up with it? Never heard one fail before.
Daniel206RC
PostPosted: Mon Aug 12, 2013 3:58 pm Up
All abs sensors are OK and all abs rings are OK. 2 fault codes I can't remember, saying that the ABS ECU is failing.
what else can it be??
Will try to get the fault codes!
03, RC / GTI180
03, SW XSI
PostPosted: Wed Aug 14, 2013 2:14 am Up
They do fail,the ECU that built inside the ABS bump fail,which make the system faulty.
PostPosted: Wed Aug 14, 2013 2:50 am Up
The ESP unit's do fail but not often on PSA fitment.
Im pretty sure it's a Teves mk 60 ESP unit on 206's with ESP & Teves mk 60 is known in the trade for being very problematic on VAG fitment Whistle...
PostPosted: Wed Aug 14, 2013 4:22 am Up
Any word on the fault codes?
