Online Now [1023]:
Visitors: 1022
Today: 61496
Total: 128435849
Forums › The Car › 206 Problems › engine coolant leak approx 50ml a minute
richy244
PostPosted: Thu Aug 15, 2013 11:59 am Up
Hello Again
My 1.1 has developed a fairly severe coolant leak about 50ml a miute, and i have to top it up with water twice a day. It appears to be coming from the water pump tho im not sure. It was changed with the canmbelt just 2 months ago using this kit...
www.ebay.co.uk/itm/Peu...0714518376
Ive checked the pipe that goes from the resovoir to the engine and that seems ok. Anyone got any clues?
PostPosted: Thu Aug 15, 2013 2:06 pm Up
Did you Put any sort of sealant on the pump when it was reattached?
PostPosted: Thu Aug 15, 2013 2:29 pm Up
Pump in tu's has a rubber gasket. Can you see any white crystals anywhere?
paulspug
PostPosted: Thu Aug 15, 2013 5:12 pm Up
Check all pipe work including matrix for leaks.
Check both water cap and engine oil filler cap for milky residue.
If residue then chances are blown head u/l.
Other than that check radiator / matrix radiator for any signs of leakage.
That's an awful lot of water to be losing. G/L
paulspug
PostPosted: Thu Aug 15, 2013 5:13 pm Up
PostPosted: Fri Aug 16, 2013 2:36 am Up
O ring seal that comes in a bag of 5 when I did mine last year.
Im down to 4 in my stock now Laughing
richy244
PostPosted: Fri Aug 16, 2013 6:33 am Up
there's no creamy residue on the oil cap or the dipstick. My instinct is that its the O ring for the waterpump. I paid a guy £80 to do the cambelt, waterpump and aux belt just 2 months ago. Dont you need to take all that off to get at the waterpump? Is there anywhere that does Strong O rings?
PostPosted: Fri Aug 16, 2013 6:38 am Up
There is nothing wrong with a genuine Peugeot / Citroen supplied part.
Go to a main dealer & buy the O ring from there.
richy244
PostPosted: Tue Sep 03, 2013 3:25 pm Up
It turned out the new waterpump that was put in just 6 weeks ago had failed and was not just the 'O' ring but the seal in the waterpump itself. Another £60 spent. New problem now is the left indicator staying on constantly i.e. not clicking. i can only turn it off by removing a fuse? is it the relay?
