Latest: Andyblue64
Overall: 17123
Online Now [293]:
Visitors: 292
Today: 66521
Total: 98254752
Forums › The Car › 206 Problems › Coolant leak from rear of pump housing
RC_Heli_Boy
PostPosted: Mon Aug 19, 2013 7:22 am Up
Hello
I have just replaced cambelt, tensioner and water pump on my 206GTi (2003). On filling the coolant tank, it is escaping from where the coolant pipe enters the coolant pump housing. I put the new O ring on the pipe prior to inserting into the pump. It seem as though the pipe (think it is metal) enters at an angle but can't seem to move it insitu. Anyone know if the pipe can be unattached from block (cant see a bracket) and inserted again etc...
Cheers
Mike
PostPosted: Mon Aug 19, 2013 2:16 pm Up
It's difficult to remove. Needs to be pulled out of the thermostat housing first before it can be pulled out of the pump. Wear gloves to avoid injuring your hands as it will come out suddenly.
PostPosted: Mon Aug 19, 2013 2:59 pm Up
I found it easier to take it out still attached to the thermostat, as said though there is not much room, and it will suddenly give!
RC_Heli_Boy
PostPosted: Mon Aug 19, 2013 4:03 pm Up
OK thanks for your replies, got battery and tray out and will try tomorrow eve, cheers
