Online Now [212]:
Visitors: 212
Today: 130579
Total: 154686993
Forums › The Car › 206 Talk › Peugeot Planet?
Peugeot Planet?
Forum Index › 206 Talk
Go to page Previous  1, 2, 3
PostPosted: Wed Aug 21, 2013 2:46 am Up
buseng wrote:
Managed it! My engine ecu.
That's a Sagem S2000 ECU but not the S23 software version that is usually fitted to 1.4i non-mux.
PostPosted: Wed Aug 21, 2013 6:36 am Up
Cancel that.^
I read more of your posts now, yours is mux and "unknown ECU > Refrencing ECU" is normal on later setups.
To read the codes, go back manualy by pressing the appropriate F key, then go to "engine ECU" and scan again.
It's a PP2000 bug that does not give the codes straight-away and I've had this before.
If you scan again from "engine ECU" and somehow keep at it, it basicaly displays everything correctly.
buseng
PostPosted: Wed Aug 21, 2013 10:31 am Up
Only just seen your post & will give your idea a try.
However, as I said, when I tried it on a friend's 2005 HDI it found the engine ecu straight away during a global search. Very strange?
PostPosted: Wed Aug 21, 2013 10:37 am Up
Global search on mine finds the engine ecu straight away.
buseng
PostPosted: Wed Aug 21, 2013 11:49 am Up
V9977 wrote:
Cancel that.^
Firstly, thank you all very much for help with this.
V9977, I tried your suggestion & it worked! Just clicked "ok" when it asked if you want to continue after not recognising the ecu.
Anyway found fault code P1327,
P1327 Ignition - Integrated Phase detection as an intermittent fault.
The EM light did come on a couple of weeks ago but went off again after a day. I have now cleared the code & will see what happens.
Can now see all the other engine parameters/readings as well.
Again, thanks very much.
Page 3 of 3
