Online Now [1048]:
Visitors: 1047
Today: 124268
Total: 151906372
Forums › The Car › 206 Problems › Rather odd clutch
Rather odd clutch
JackRadd
PostPosted: Tue Aug 20, 2013 4:40 am Up
Hello,
So yesterday coming off the m6 I approach the roundabout. Come to a stop to give way, I then go to pull off and my foot sinks into the clutch pedal with a nice click/crunch noise. From then it stalled and took a couple of attempts to start, finally starts and I slowly pulling away, very hard to get to any other gears.
I had recently be quoted on a new clutch at a near garage (my bearing is rather loud) and dropped it off there. About 5 mins before I get to the garage my clutch comes back and performs as should?
The garage has just rang saying they can't find an issue?
Any thoughts at all would be greatly appreciated.
Many thanks
chrisd
PostPosted: Tue Aug 20, 2013 5:44 am Up
Clutch cable auto adjuster has gone cable needs replaced
PostPosted: Tue Aug 20, 2013 8:20 am Up
I would tend to support the view that auto adjuster has failed. However a cabloe is about £40 and can't be reused. If your thrust bearing is genuinely noisy you might still consider doing both jobs at once. Of course your bearing may be noisy because the clutch cable auto adjuster is failing.
I bet which ever you decide to do will, in the longer run, be proven to be wrong. That is life!
JackRadd
PostPosted: Tue Aug 20, 2013 8:48 am Up
Thanks for the replies, spoke to the garage to have a look at all possibilities included ones listed, but no luck.
For the piece of mind I have gone for a full new clutch kit, rather noisy and high so to me it was due.
Again many thanks
PostPosted: Wed Aug 21, 2013 12:23 pm Up
A full new clutch kit MUST include fitting a new cable. Do not let them fob you off that the existing cable is OK. The cable will probably operate nicely but because the auto adjustment can't be reset reusing the existing cable will trash your clutch, pressure plate or thrust bearing very quickly. Also please use a true genuine Peugeot cable bought from Peugeot as they are far superior.
More expensive yes but I wouldn't use a pattern cable on my car.
JackRadd
PostPosted: Wed Aug 21, 2013 1:43 pm Up
Thanks, I got my car back today with full kit and cables. It feels great and also a 12 month/ 12000 mile warranty so should go well... Just need to get used to the low bite and smooth gears.
Cheers again
