Latest: Mr-Koekwaus
Overall: 17125
Online Now [349]:
Visitors: 348
Today: 27081
Total: 99857684
Forums › The Car › 206 Problems › what grade engine oil in a gti??
omega
PostPosted: Thu Aug 22, 2013 2:48 pm Up
been using Castrol engine oil but been told its to thin and not very good
is this correct?
what is the correct grade oil to use
cheers
Ben.M
PostPosted: Thu Aug 22, 2013 2:53 pm Up
The grade varies between different oil companies, the best one is generally agreed to be Total Quartz 9000 5w40.
Lecktorious
PostPosted: Thu Aug 22, 2013 3:40 pm Up
Trade Rating: +59
Does it not tell you on a sticker on the slam panel?
'98 Nile Blue 306 GTi 6
magistar
PostPosted: Thu Aug 22, 2013 4:25 pm Up
i was using castrol 5w-40 for two years and my gti was burning it up like crazy. basically had to top it up every 2 months. I've since switched to valvoline 10w-40 and its a major difference as it doesn't get burnt up much at all. Been thinking of giving Shell a try too as my peugeot garage uses shell.
JamesG958
PostPosted: Sat Aug 24, 2013 1:08 pm Up
I found a really good website for this its called opie oils
link : www.opieoils.co.uk/pro...der-2.aspx
Just find your car and it comes up with the correct type of oil. Hope this helps
EDIT: Also tells you how much you need to put in so youu dont overfill or underfill it
omega
PostPosted: Sun Aug 25, 2013 11:49 am Up
Very Happy thanks
that says 5w 40 but mine users a bit same as magistar so might try the 10/40
1245678
paulspug
PostPosted: Mon Aug 26, 2013 1:03 am Up
ive always used this on my 206's and never has it used much, even after 6 months its not used any. its a damn good oil Wink
