Latest: Makomeister18274
Overall: 17122
Online Now [57]:
Visitors: 57
Today: 30289
Total: 97809250
Forums › The Car › 206 Problems › o2 Sensor
o2 Sensor
IceWhyte
PostPosted: Sat Aug 24, 2013 1:34 pm Up
I think my lambda sensor is faulty as I am getting codes p0130, 135 & 170.
I already bought a lambda sensor for it but I am assuming it was not up to standard as it was a £20 one from eBay.
Does anyone have any advice on a make of lambda sensor which is good quality? I was looking at Boshe and NGK ones but they are really expensive, but will buy one if needed.
PostPosted: Sat Aug 24, 2013 3:37 pm Up
Did you clear the fault after changing them? The car will just think its still got the faulty lambda otherwise.
IceWhyte
PostPosted: Sun Aug 25, 2013 8:14 am Up
Thanks for that but yes the fault has been cleared several times but always returns.
PostPosted: Sun Aug 25, 2013 11:32 am Up
Did you replce it with a new or used one?
IceWhyte
PostPosted: Sun Aug 25, 2013 12:21 pm Up
It was new but it was a cheap one.
IceWhyte
PostPosted: Mon Aug 26, 2013 12:12 pm Up
Oh well nevermind. I ordered an NGK one.
IceWhyte
PostPosted: Sun Sep 01, 2013 6:00 am Up
Got the NGK one fitted and it has solved the problem.
naser-abdi
PostPosted: Sun Sep 01, 2013 6:29 am Up
Hi,
My car is 206, when i do diagnostic scan, I am getting error as o2 Sensor shortcut!
Does anyone has a solution?
IceWhyte
PostPosted: Sun Sep 01, 2013 5:22 pm Up
You would be better creating a new thread about your problem. Be sure to provide as much detail as possible such as error code number etc.
