Latest: Mr-Koekwaus
Overall: 17125
Online Now [498]:
Visitors: 497
Today: 53011
Total: 99883567
Forums › The Car › 206 Problems › Technical question
Technical question
Aimon
PostPosted: Mon Aug 26, 2013 10:18 am Up
When stepper motor of idle is replaed replaced by new one, Does it need any configurations or data to be entered to ECU???? If yes, what is this data? What is its importance? Sad
PostPosted: Mon Aug 26, 2013 10:27 am Up
Fit and forget.
Aimon
PostPosted: Mon Aug 26, 2013 10:42 am Up
Edward wrote:
Fit and forget.
Fit and forget=Plug and play??????
PostPosted: Mon Aug 26, 2013 12:29 pm Up
Idle control valves require no coding or adaptive resets
Fit and go
