Online Now [350]:
Visitors: 349
Today: 20379
Total: 156257529
Forums › The Car › 206 Problems › 180 shuddering when pulling away
tommyhon23
PostPosted: Fri Aug 30, 2013 10:43 am Up
So my gti 180 is shuddering from the engine like crazy everytime i pull away from a stop. Ive had the clutch done about 2 month ago. So is it just that thats been done badly? Ive been told it might be the flywheel? Thanks:-)
Tom
Peugeot 206 1.4- black
Peugeot 206 gti 180- black
Registration- F1 TPH
L5_UKS
PostPosted: Fri Aug 30, 2013 11:50 am Up
Yep sounds like a warped flywheel if you have already had the clutch done. They should have checked that when they fitted the new clutch.
PostPosted: Fri Aug 30, 2013 2:25 pm Up
Get the clutch rebled, worked in my case.
tommyhon23
PostPosted: Fri Aug 30, 2013 2:32 pm Up
What does 'rebled' mean? :$
Tom
PostPosted: Fri Aug 30, 2013 2:42 pm Up
Its an Hydraulic clutch, using the brake fluid reservoir. Mine had air in it meaning the clutch wasn't engaging properly. Mine had terrible judder, and used to 'jump' when changing gear.
tommyhon23
PostPosted: Fri Aug 30, 2013 2:48 pm Up
Ok great thanks for your help
Tom
PostPosted: Fri Aug 30, 2013 11:11 pm Up
Could be a dodgy clutch or the way it was put in, or maybe an engine mount.
tommyb32
PostPosted: Wed Sep 04, 2013 9:04 am Up
could be engine mount but 180's are notorious for warped flywheels....
