Latest: sparrowdclxvi
Overall: 17139
Online Now [509]:
Visitors: 508
Today: 80973
Total: 112892543
Forums › The Car › 206 Problems › water coming out of the mannifold
tom94
PostPosted: Fri Aug 30, 2013 12:17 pm Up
hi all brought a 206 1.4 2001 last week, the bloke we brought it off said that the coolant keeps running low not everyday, it might be ok for a few days then itl all be gone.
however today the car just started driving really roughly and when i went to start it again it wouldnt start and water kept p**sing out of the mannifold, clear water not oil or grime.
any ideas what is wrong with it? it was only m.o.t'd 3 weeks ago surely they would have picked up on this?
can it be repaired? please help im desperate.
thanks
Tolkienfan001
PostPosted: Fri Aug 30, 2013 12:33 pm Up
Trade Rating: +13
With my limited knowledge I would guess at the head gasket has gone?
2005 1.4 16v Sport
Check out my 206 here!
tom94
PostPosted: Fri Aug 30, 2013 12:39 pm Up
thanks for the reply, thats what im getting back that its either the head gasket or the head has cracked, how do i know which one it is?
PostPosted: Fri Aug 30, 2013 12:41 pm Up
Do these have a water heated inlet?
Tolkienfan001
PostPosted: Fri Aug 30, 2013 12:46 pm Up
Trade Rating: +13
If you are like me you need someone who knows a lot more to take a look at it. Better than guessing and worrying about the worst!
2005 1.4 16v Sport
PostPosted: Fri Aug 30, 2013 1:58 pm Up
well if the water is coming out from manifold,then you have a problem in the engine head itself,as there is coolant (water) lines inside the head are broken,and the water is running inside the pistons,which make the water go with the exhaust.
