Online Now [661]:
Visitors: 660
Today: 25002
Total: 154236317
Forums › The Car › 206 Problems › Downstream oxygen sensor?
karimali831
PostPosted: Mon Sep 02, 2013 6:38 am Up
Hi guys, I have ran pp2000 after 6 months to check any faults and I am getting 1 from the engine ECU, "Intermittent fault. Downstream oxygen sensor Short-circuit to positive or circuit open". The engine management light does not illuminate for this. Anyone know what this is for and how I can get it fixed?
And the left handbrake cable has snapped should I be looking at buying 1 or 2 cables?
206 GTI 180
PostPosted: Mon Sep 02, 2013 6:53 am Up
Check your connections on the lamda sensor. Will be the second one. I would replace in pairs, will both be the same tension and should last you a whiile. Saying that I have no idea how much they cost.
karimali831
PostPosted: Mon Sep 02, 2013 9:25 am Up
Thanks mate for the reply.
Would of thought 1 hour labour, will buy the parts online.
206 GTI 180
