Online Now [515]:
Visitors: 514
Today: 121828
Total: 157143511
Forums › The Car › 206 Talk › Cam Belt 206 GTI
Cam Belt 206 GTI
Forum Index › 206 Talk
Go to page 1, 2, 3, 4  Next
Zack
PostPosted: Mon Sep 02, 2013 10:19 am Up
Is the tensioner auto?
PostPosted: Mon Sep 02, 2013 12:58 pm Up
No. Needs to be set when you tighten it up. Just done mine.
Zack
PostPosted: Mon Sep 02, 2013 2:58 pm Up
How tight did you do it?
PostPosted: Mon Sep 02, 2013 3:01 pm Up
Are you doing yours? Do you know how and where to set the notch? I used a Torgue wrench to whatever the Haynes says.
Zack
PostPosted: Mon Sep 02, 2013 3:03 pm Up
Ill use a wrench to. Not just taking it a part and puting it together the same way it came off.
Y?
Zack
PostPosted: Mon Sep 02, 2013 3:10 pm Up
What year is your car it a gti
PostPosted: Mon Sep 02, 2013 4:25 pm Up
There is a bloody pointer on the tensioner. Set it between the two marks and tighten.the nut tight, approx 30nm
Zack
PostPosted: Mon Sep 02, 2013 5:03 pm Up
Thanks that's all I needed to know Smile
dannyboy-gti
PostPosted: Wed Sep 04, 2013 9:51 am Up
Is there a how-to anywhere for changing the belt?
Zack
PostPosted: Wed Sep 04, 2013 9:53 am Up
Ent got a clue would be good for one Smile am just going to go all in if it fails then opps .
PostPosted: Wed Sep 04, 2013 1:24 pm Up
Guaranteed fail then. Hope all goes well...
If anyone else wants to do it properly, its not hard but you need to know what your doing with regards to timing holes and tension. Hardest bit is the tight space!
Zack
PostPosted: Wed Sep 04, 2013 1:48 pm Up
Only reason am game for doing it because did my first cam belt weekend just gone on punto.
I have the lock tools for timing holes
Not doing it just yet a takes pictures when a do it.
Thanks for people's info.
Zack
PostPosted: Thu Sep 12, 2013 4:55 am Up
What water pump to get?
www.eurocarparts.com/e...a4d&000366
www.eurocarparts.com/e...c71&000366
Ones with housing ones without
Cheers
Zack
PostPosted: Thu Sep 12, 2013 5:00 am Up
Am going with top
PostPosted: Thu Sep 12, 2013 7:37 am Up
Bought mine from Peugeot recently. £67. You'll also need a new o ring.
Page 1 of 4
