Online Now [321]:
Visitors: 319
Members: 1
Today: 68876
Total: 155939302
Forums › The Car › 206 Problems › peugeot 206 gti 180 rough idle when cold
gogs_macaulay
PostPosted: Wed Sep 04, 2013 2:05 pm Up
as above, when i start and drive my car from cold after a very short distance ill stop say at a junction and the car idles rough. what could this be?
Barking
PostPosted: Wed Sep 04, 2013 2:19 pm Up
It wants some beans. Drive it how it begs to be driven!
Unless it cuts out I wouldn't worry about it - it could be the heat, dirty fuel, dirty or blocked air filter, or the menopause
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Wed Sep 04, 2013 2:30 pm Up
Temp sensor feeding ECU defective? The ECU will think the car is warm so runs lean and stalls..
Alternative is throttle body clean required.
shell-vt
PostPosted: Wed Sep 04, 2013 2:42 pm Up
Trade Rating: +46
vvt buddy common do a search
york 16,3
broadblaster
PostPosted: Wed Sep 04, 2013 3:08 pm Up
i would start with the temp sensor.
on a back road playing
gogs_macaulay
PostPosted: Wed Sep 04, 2013 3:14 pm Up
how much is a new vvt solenoid? my car did run kinda low torque on the dyno.
part no for temp sensor?
mattymj
PostPosted: Wed Sep 04, 2013 4:17 pm Up
Would a faulty temperature sensor not put the eml light on. Im having rough idle issues too
PostPosted: Thu Sep 05, 2013 9:32 am Up
Only if it goes out of it's working range which I've yet to see one do on a PSA product.
mattymj
PostPosted: Thu Sep 05, 2013 10:23 am Up
Ok well purchased one today from eurocarparts. Hope its good enough.
mattymj
PostPosted: Thu Sep 05, 2013 1:49 pm Up
Hi, got the new sensor fitted, refilled the coolant system (only managed 5 litres in! Supposed to be 8.2) ran the car to get it up to temperature, got antipollution fault from the new sensor, voltage too high! Cleared the fault and hasn't come back. The car seems to be running smoother, the over fuelling smell has gone and something happened that never has before, the miles in the tank gauge was rising lol, went from 50 to 62! Would this be the ecu accounting for the car no longer over fuelling. Thanks. Sorry about rabbitting on.
mattymj
PostPosted: Thu Sep 05, 2013 4:25 pm Up
Any ideas why i only managed to fit 5 litres in?
gogs_macaulay
PostPosted: Fri Sep 13, 2013 2:18 pm Up
new temp sensor. problem gone Smile
mattymj
PostPosted: Fri Sep 13, 2013 3:46 pm Up
Gdgd
PostPosted: Thu Sep 19, 2013 2:56 pm Up
+ incorrect fuelling due to faulty temp sensor will affect power output and possible cause of low power on dyno
dubdup
PostPosted: Fri Sep 27, 2013 4:55 am Up
Just moved from standard GTI to the 180, getting the same issue, going to do a plug change as matter of course, do you have the part code for the temp sensor from Euro, did you fit yourself? if so, where is it located and much of a job?
Cheers
