Posted: Sat Sep 07, 2013 11:32 am |
When I floor the accelerator with the obd reader plugged in it only showing as 80% open. Is that unusual?
Posted: Sat Sep 07, 2013 12:48 pm |
I have no idea if that's right or not but, do you have a floor mat?
That might rob you of 5-10%, just a thought.
This may also help you:
206gti.net/throttle-cable/
Regards, Richard.
Posted: Sat Sep 07, 2013 12:52 pm |
No mate. The pedal is hitting the stop. I do know minis suffer with this as a restriction from the dealer. A remap opens them to 100%
Posted: Sat Sep 07, 2013 4:31 pm |
Remove the air intake and see what is actually happening.
Posted: Sun Sep 08, 2013 3:09 am |
I have. It looks to be fully open. Could the 80 be degrees?
Posted: Sun Sep 08, 2013 3:31 am |
If the ecu only opens it 80% surely it won't be running as much power. Can any other 180 owners check theirs?
Posted: Sun Sep 08, 2013 8:53 am |
Mine too. PPS2000 reads not full open, while throttle body is...
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Sun Sep 08, 2013 1:46 pm |
Oh! Could this be a restriction. As I know rc version make more power
Posted: Mon Sep 09, 2013 2:06 am |
Is it 80 % though gpvecchi?
Posted: Mon Sep 09, 2013 6:25 am |
Will the extra 20% actually make any difference though? Maybe the TB isn't restrictive at all even at 80% open.
Posted: Mon Sep 09, 2013 7:33 am |
I just wonder if the fuelling would change. If the ecu is seeing 80% and wonder if 100% would make it put more fuel in making more power
Posted: Mon Sep 09, 2013 10:13 am |
Is this 80% reading taken when the car isn't moving OR when driving along?
Posted: Mon Sep 09, 2013 11:23 am |
Hi. It's 80% in both modes. Will never go any higher
Posted: Mon Sep 09, 2013 11:53 am |
I reckon the engine is swallowing as much air as it can even at 80% open. Therefore the throttle body isn't restrictive at all.
Posted: Mon Sep 09, 2013 12:32 pm |
The issue appears to be that the 80% shown with PP relates to an actual 100% and I think the question will be:-
Is this how ALL of this model engine management system is set up or is there a problem with this one?
If it is correct that they are all like this I would then want to know why but that is another question completely.
