Latest: Andyblue64
Overall: 17123
Online Now [397]:
Visitors: 396
Today: 21491
Total: 98050896
Forums › The Car › 206 Talk › Front suspension
Front suspension
Mike_XS
PostPosted: Mon Sep 09, 2013 2:30 am Up
Morning everyone,
I'm looking at raising the 206. It's down 40mm at the moment, but I don't want to raise it back to standard ride height. I believe the GTi is 15mm lower than the XS. Would it be possible for me to fit oem GTI springs to my bilstein shocks?
Cheers Smile
tRiCk
PostPosted: Mon Sep 09, 2013 4:31 pm Up
I guess if your old springs were standard format you have a chance, if your Bilstein shocks are not specifically lowering dampers, the should work with standard springs.
Which Bilstein dampers do you have, B4, B6 or B8?
Mike_XS
PostPosted: Wed Sep 11, 2013 1:39 am Up
The dampers as far as I know aren't specifically for lowering. I can't remember which ones they are though. Think they are B4 though. I'll try and find out though!
Mike_XS
PostPosted: Wed Sep 11, 2013 1:41 am Up
If it helps, there is a comparison picture of the old and new springs here.
206info.co.uk/Forums/v...rt=60.html
