Posted: Sun Sep 08, 2013 2:57 pm |
Hello,
Can anyone please help, my 206 (2005) main and dipped beam on the right hand side (drivers side) are not working?
I have checked the bulbs and fuses and they are both good??? The side light is ok on the right hand side and there is no warning lights/indicators, can anyone please help???
Many thanks for all your help. Hope to hear from you soon.
Posted: Sun Sep 08, 2013 5:14 pm |
well take the bulbs out,and use a multimeter to check for voltage,if there is no voltage there,then you need to check the harness.
Posted: Mon Sep 09, 2013 1:18 am |
Check the earth below the headlight.
Posted: Mon Sep 09, 2013 10:14 am |
Steve206 wrote: |
Check the earth below the headlight. |
Known 206 issue.
Posted: Tue Sep 10, 2013 3:30 am |
Had same problem give the connection a push up and down where the plug slots into the light unit if it works then pull out both plugs cut the wires and rejoin them with a connector block make sure u look how the wires join in to the plugs other wise you may burn out the loom lol
