Online Now [117]:
Visitors: 116
Today: 54670
Total: 117008636
Forums › The Car › Solved 206 Problems › help with wiring, fuel pump live, imobiliser wiring
usher
PostPosted: Sun Sep 29, 2013 6:22 am Up
i have been removing wiring in the car and the last stint saw the car not starting, i started on the fuse box and bsi unit, its a 2000 reg gti, the fuel pump live (white wire ion ds footwell) goes to the connector block then splitts to a yellow and pink wire but i have cut them at the connector and cant find where they end up, the fuse box has all wires in for the pump so at a dead end unless it goes to another connector first,
second the imobiliser seems to be active as there is no spark i have removed the sensors for the alarm and central locking but the car stilll fired as they were removed ages ago, also with the bsi it beebs and the power steering and ecu make the same noises but the wipers come on when i tur the ignition
anyone that can shed light on this ??
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Sun Sep 29, 2013 1:02 pm Up
Trade Rating: +46
ultamate sin matey you have rushed it, anyway best thing to do now it get a unlocked ecu and re-wire thye fuel pump up unless you re trace all the wires you have cut re atach and start again,
york 16,3
usher
PostPosted: Sun Sep 29, 2013 3:59 pm Up
I was starting the car after cutting but didn't one day as I was mainly removing dead wires but can't find the wires with the right serial codes so at a real dead end atm going to a scrap yard one day when I can to look at the wiring which should help but the odds of it been a gti are slim. Worst case I get a standalone ecu and wire that in with universal switches for lights etc. I assume it's immobiliser being the main problem but there are no diagrams for it that I can find
project thread WIP
garage
FAQ
206 gti firedance
shell-vt
PostPosted: Mon Sep 30, 2013 5:09 am Up
Trade Rating: +46
option 2 is fare better usher im going down that route myself
york 16,3
usher
PostPosted: Mon Sep 30, 2013 11:44 am Up
Just a little nervous about it as the interior wasn't too difficult but re wiring the engine to a new ecu seems a little daunting. It wouldn't be a waste of money or costly mistake as throttle bodies will be happening at some point
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Mon Sep 30, 2013 2:12 pm Up
Don't know why you'd cut any wiring to the back of the car. So little of it can actually be removed. If anything is redundant then don't cut, just remove the pins from the plugs and take the wiring out.
usher
PostPosted: Mon Sep 30, 2013 3:04 pm Up
bit late now lol but i have removed 2 carrier bags full of wires so there plenty that isnt needed just a few single wires that need putting back in but where and from where i dont know yet, might be a new ecu but which one??
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Tue Oct 01, 2013 6:14 am Up
Other than stuff like the rear wiper, airbag and speaker wiring what can be removed?
usher
PostPosted: Wed Nov 06, 2013 9:02 am Up
Fuel pump live anyone know where it comes from
project thread WIP
garage
FAQ
206 gti firedance
PostPosted: Wed Nov 06, 2013 9:21 am Up
PM'd
usher
PostPosted: Sun Jan 05, 2014 8:09 am Up
solved by putting a new loom in
project thread WIP
garage
FAQ
206 gti firedance
