Latest: Flyin180
Overall: 17116
Online Now [177]:
Visitors: 176
Today: 30554
Total: 95169819
Forums › The Car › 206 Problems › Gti 180 engine problems
Go to page Previous  1, 2
Barking
PostPosted: Fri Apr 29, 2011 1:47 am Up
timing?
cambelt recently fitted?
I got a dig bick.
You that read wrong.
You read that wrong too.
bigtony85
PostPosted: Fri Apr 29, 2011 3:50 am Up
cam belt changed bout a year ago problem on started bout 3 month ago
drive fast !!! live life faster !!!
Barking
PostPosted: Fri Apr 29, 2011 4:31 am Up
check your belts are not slack, as it sounds like a timing issue tbh
I got a dig bick.
SAB206
PostPosted: Fri Apr 29, 2011 6:19 am Up
Exhaust noise didn't change did it when cambelt was done?
www.sab-graphics.com
I AM SYDLEXIC!
bigtony85
PostPosted: Sat Apr 30, 2011 5:23 am Up
no exhaust noise was the same after the cam belt fit changed bout 3 months ago
mattymj
PostPosted: Wed Jul 17, 2013 1:56 pm Up
Did this get fixed?
dubdup
PostPosted: Wed Oct 02, 2013 4:11 pm Up
Same here, I'd be interested to find out if you sorted. I have similar fault, changed Temp sensor (cheers for heads up on that Mattymj), that cured poor revving, but get the same drop/recover of rev's usually when changing gears or if I blip the throttle.
Page 2 of 2
