Online Now [229]:
Visitors: 228
Today: 119768
Total: 155076016
Forums › The Car › 206 Problems › front pulling under braking
chefboy1985
PostPosted: Sat Oct 12, 2013 1:23 am Up
After fitting my brembos all was well but just reasantly I have noticed infer heavy braking it is pulling to the left and can't figure out y???anyone had experience of this or would know wat would cause it?
chriswiked
PostPosted: Sat Oct 12, 2013 9:05 am Up
sounds like un even pressure, check the pads on the other side and look for wear maybe put new pads on both sides to even it out
chefboy1985
PostPosted: Sat Oct 12, 2013 11:28 am Up
They are just new pads tat are on,wil put it into a garage this week get the brakes bleed and fluid changed.
PostPosted: Sun Oct 13, 2013 1:15 pm Up
Possible sticking piston. In fitting new pads you have pushed the piston right back into the calliper and if the previously exposed part of the piston was dirty or corroded that can cause the piston to stick or need extra force to move it.
It could also be worn swivel joint allowing one wheel to turn slightly under hard braking.
It could be air in the system so bleeding is worth a try.
It could actually be one of the rear brakes not working correctly, that will also cause the car to pull under braking.
chefboy1985
PostPosted: Mon Oct 14, 2013 2:05 am Up
