Online Now [527]:
Visitors: 526
Today: 122015
Total: 156474316
Forums › The Car › 206 Problems › 206 Flat Spot
206 Flat Spot
silverfox1264
PostPosted: Mon Oct 14, 2013 7:22 am Up
Hi,
Today my 206 seems to have a flat spot in 2nd gear, the engine light flicked on/off. The car just had a new exhaust to pass MOT last week.
When accelerating in 2nd the car will not go like it used to, all other gears seem as normal.
Not sure if its related or not, but the car runs fine other than that.
im new
paulspug
PostPosted: Thu Oct 17, 2013 6:58 am Up
had the same problem on my 180 but in 5th gear. Turned out to be a slight blow in the exhaust. Since you have just changed yours , maybe worth a look over to make sure nothings leaking.
