Latest: eltel666
Overall: 17146
Online Now [105]:
Visitors: 104
Today: 13664
Total: 116150693
Forums › The Car › 206 Talk › any common faults with 206 GTI HDI 1.6
dsiingh
PostPosted: Tue Oct 15, 2013 2:37 am Up
Hi all,
I am on the look out for a GTI HDI 206 are there any common faults or problems to look out for? I have posted a 'want' in the wanted section too.
Thanks,
dsiingh
Pug 206 1.4 SW - July 2013 - Present
Peugeot 206 1.4 HDI - Oct 2013 - Present
BMW E30 - April 2013 - RIP
PugJH
PostPosted: Tue Oct 15, 2013 2:40 am Up
Plenty. Search it. But most would say it's the worst 206 engine. Faptastic.
You often get anti pollution fault or something along the lines of the dpf blocking.
WIP: Black 1.6 16v XSi
Beauté Noire
dsiingh
PostPosted: Tue Oct 15, 2013 3:13 am Up
Forgot about that little search feature, i'd be driving it up and down on the motorways so it'll regenerate the dpf , or is it just a random fault which comes up
206HdiGti
PostPosted: Tue Oct 15, 2013 4:11 am Up
It doesn't work driving up and down motorways if it's completely blocked, you'll either have to replace it or have it removed with the ECU software changed. Costs around £500 which is a lot cheaper than having the unit replaced by Peugeot.
Even with it removed you'll still have the additive warning message come up. Mine has been on for 2 weeks now, just got to drop the tank and pour some diesel or AdBlue into the reservoir to cure the problem.
Various electrical issues have arisen like ABS and ESR faults. But these go away if you turn the car off and back on again.
The only annoying issue I have currently is the Aircon as sometimes it has a mind of its own and blows out cold air when its meant to be hot and sometimes the other way around. Very awkward now the mornings are getting cold!
dsiingh
PostPosted: Tue Oct 15, 2013 4:33 am Up
So it has some electrical devils underneath? Can these be rectified, how much have you spent on it in repairs etc(if you dont mind me asking)
Lecktorious
PostPosted: Tue Oct 15, 2013 5:05 am Up
Trade Rating: +59
Laughing
As said above, use the search function. It's been covered before and there are more faults than the DPF to look out for.
'98 Nile Blue 306 GTi 6
206HdiGti
PostPosted: Tue Oct 15, 2013 6:52 am Up
It cost me £450 to remove the DPF and that is the only money i've spent on it, other than a service and I have covered 22k miles this year.
mehoolkmusic
PostPosted: Tue Oct 15, 2013 8:48 am Up
Ive had this same engine in our 407 1.6 hdi and it was a pleasure to own, i think all these engines are dv6, it really depends how you maintain the car, on my one the oil was changed every 6k miles along with filter plus additive. Only problem we had which knew the car was on its way out was around 100k the low oil pressure light, which we changed the pump we bought off ebay iirc for around £50, changed the oil and filter again drove fine. Then a month later the turbo went, so sold it and bought a Touareg :). Id go for the 407 1.6 hdi or the 2.0 hdi, over the 206 as you can pick them up cheap.
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
mehoolkmusic
PostPosted: Tue Oct 15, 2013 8:50 am Up
Forgot to say it was a 07 plate we bought around 2009 with 50 odd thousand
Lecktorious
PostPosted: Tue Oct 15, 2013 10:19 am Up
Trade Rating: +59
Same engine, different car and generation so not really relevant for the 206.
mehoolkmusic
PostPosted: Tue Oct 15, 2013 10:44 am Up
Yeah what im trying to say is, the engine is good as long as you maintain is properly, then again its your luck i suppose with cars.
dsiingh
PostPosted: Tue Oct 15, 2013 1:48 pm Up
Yeah sometime it is down to look, depends what the previous seller or dealer hides from you at the point of sale. I am considering purchasing one as ill be doing a lot of motorway miles and petrol isnt rewarding me with any savings
kwakzx7r
PostPosted: Tue Oct 15, 2013 4:01 pm Up
Got a GTI HDI 6 weeks ago and love it. Looks very similar to my old GTI 180 which I like.Pulls like a train, handles like a GTI, and more torque than the GTI 180. On a run its giving 60mpg and day to day 20 mile run each way to work its avg 53mpg Smile
IF you get the DPF fault they can be replaced for just over £200
www.ebay.co.uk/itm/130...1423.l2649
Or you can have it removed and remapped for approx £400-£500
Find a good one with full history and well serviced and keep it serviced and im sure you'll enjoy it. But like any older car don't expect 100% reliability
PostPosted: Tue Oct 15, 2013 4:07 pm Up
Summarised for everyones sake:
- DPF clogging
- Additive fluid level
- Injector Leaks
- Turbo failure (via blocked oil lines normally)
- Airbox intake pipe loose
- Oil pump seal leak
- Engine failure via sump pick up blocked
- Fuel filter waxing (very common in winter!)
I will always state the engines are amazing, but only if they have been serviced regularly!
kwakzx7r
PostPosted: Wed Oct 16, 2013 9:43 am Up
LMAO must have jinxed myself last night with my post. driving to work this morning and what pops up on the dash "ANTI POLLUTION FAULT" Typical lol
