Latest: DanDan17
Overall: 17128
Online Now [51]:
Visitors: 50
Today: 31799
Total: 100506562
Forums › The Car › 206 Talk › Need a code reader for old type 206
greenpug2222
PostPosted: Wed Oct 16, 2013 6:33 am Up
Hi,
I have a old type (2000 a reg) 206 and need a code reader/ scanner.
Can someone point me in the right direction through eBay or amazon.
Many thanks
Joe
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Wed Oct 16, 2013 6:37 am Up
I've got an Autel Maxiscan for my December 2000 build 206 GTi, Works fine. They are about £30 from Amazon.
PostPosted: Wed Oct 16, 2013 7:50 am Up
Although OBDII compliance was only required on petrol cars sold in Europe after 2001, many manufacturers who sold vehicles in the USA started using it in 1996 when it became mandatory over there.
Might be worth seeing if someone close by has a scanner that they can try on it, and then you'll have some idea of what to buy.
greenpug2222
PostPosted: Thu Oct 17, 2013 2:17 am Up
Thanks,
So is there anyone in or near to Bradford that wants to help,?
