Online Now [481]:
Visitors: 480
Today: 105715
Total: 156820798
Forums › The Car › 206 Problems › peugeot 206 1.4 electric windows side mirrors not working
coolhas
PostPosted: Thu Oct 24, 2013 6:00 am Up
hi all my windows switch both sides and side mirrors electric movement are not working at all what could this be i have checked all the fuses and they seem to be fine
peugeot 206 1.4 52 plate
iainlovatt
PostPosted: Thu Oct 24, 2013 8:13 am Up
If you are sure about the fuse, then try replacing the switch!
Does your cig lighter still work?
(My Garage)
Lowiee
PostPosted: Thu Oct 24, 2013 2:56 pm Up
firstly does the switch light up but not operate you can release the switch and unclip the top section of plastic to see better if its lighting up if so change the switch had this happen to mine a few days ago if its not lighting up check power is getting to the switch
