Posted: Thu Oct 24, 2013 9:19 am |
Also is it quicker to replace the air filter first or spark plugs first?
Thanks,
Posted: Thu Oct 24, 2013 10:14 am |
Unbolt the coil pack lift off, use a spark plug socket, undo the the spark plugs.
Replace and refit coil pack. Easy 10 minute job.
Posted: Thu Oct 24, 2013 11:23 am |
| macca1411 wrote: |
Replace and refit coil pack. Easy 10 minute job. |
Nice one, thanks.
Posted: Tue Nov 05, 2013 10:43 am |
| macca1411 wrote: |
I attempted the task today.
Silly question, can I just pull the spark plugs out or unscrew them?
What mm Socket/Spanner do I need to get the spark plugs out?
The angle to access the spark plugs looks like a 45 degrees so how do I get them out without the socket/spanner bar conflicting/touching throttle body housing?
Finally I bough Bosch Super Plus spark plugs, what mm do I need to tighten them?
