Posted: Mon Oct 28, 2013 1:23 pm |
Hi guys just a quick one (i hope) driving home from work and my abs light came on and brakes definatly feel abit different, stop off into sainsburys hoping it would be fine when i got bqck in. Nope it was still on, then it went off, then it stayed on all the way home.
Is there anything i can check or common faults to no about before taking it to a garage??
Posted: Mon Oct 28, 2013 1:27 pm |
Could be a ring or a sensor or could be something completely different. Only way to narrow the problem down is to see if a code pops up when it's plugged into diagnostic equipment.
Posted: Mon Oct 28, 2013 2:33 pm |
the short and fastest way is to have code read,this way nothing to puzzle you.
Posted: Mon Oct 28, 2013 3:16 pm |
Thanks - Going to hopefully get it done tomorrow! Wish me luck....
Posted: Tue Oct 29, 2013 4:39 am |
On the way to town this morning it went off and stayed off... does this sound like a sensor on its way out or a loose connection??
Posted: Tue Oct 29, 2013 7:45 am |
Trade Rating: +59
Look on the driveshafts for a cracked ABS ring or get a diagnostic done. Otherwise you're just guessing.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Tue Oct 29, 2013 8:38 am |
Check the wiring to the abs sensors ...
Wonder if the rain yesterday could have been a factor?
Posted: Tue Oct 29, 2013 11:07 am |
If the abs ring has cracked, i would take off the sensor off for the time being, until you get the abs ring fixed, as when the rings go they obviously enlarge themselves and then tend to wear out the sensors.
You will experience intermitent faults like you are having in the mean time.
| 206 2ltr Hdi glx 53 plate | |
Posted: Tue Nov 05, 2013 9:58 am |
I had the car plugged in to a machine today but nothing came up on it, the mechanic did say my pads and discs are very worn could this do it??
