Online Now [457]:
Visitors: 456
Today: 112596
Total: 156990459
Forums › The Car › 206 Problems › screen washer bottle
bashyy1
PostPosted: Wed Oct 30, 2013 5:13 pm Up
Does anyone here know how to re-fit it once removed?
Aegean Blue Gti 180.
Project Thread
DanT
PostPosted: Wed Oct 30, 2013 6:27 pm Up
Im a bit confused, did you remove it? If so then just fit it the reverse to how you removed it?
bashyy1
PostPosted: Wed Oct 30, 2013 7:24 pm Up
It's not that simple.
It's just one screw that holds it on, i can get the bottle sat back in the right position but the holes won't line up for me to put the screw in. It's like a centermeter off. It's in such an awkward no matter how much i try and move it it won't line up.
Project Thread
bashyy1
PostPosted: Thu Oct 31, 2013 1:02 pm Up
sorted
Project Thread
DanT
PostPosted: Thu Oct 31, 2013 1:35 pm Up
What was causing it to be out of line then? Because i was going to say i know how they are fixed ive had mine off before and didnt have much problem getting back on.
bashyy1
PostPosted: Thu Oct 31, 2013 4:16 pm Up
Yeah I can imagine them being easy to fit normally, problem with mine was I had a little bump a while back and the metal was bent, making it impossible to line back up with the screw hole, had to try get it back in shape, finally got there haha
Now that's out the way I can get on with fitting my grill (god help me)
Project Thread
DanT
PostPosted: Fri Nov 01, 2013 4:47 am Up
Haha ah i see! Glad you got it sorted, what grill you fitting? Sp? Fairly easy to be honest long as you have the clips haha. Takes a bit of adjusting here and there to get it to fit the curvature of the bumper though i found with mine.
bashyy1
PostPosted: Fri Nov 01, 2013 8:18 am Up
Cheers bud.
Yeah I got the clips when i bought the new style SP badge, Yeah man I'm just wondering if I should go to the lengths of taking the bumper off to do it or not, seems a lot of work. Do you know if it actually looks any different if you fit it without taking it off?
Project Thread
Tolkienfan001
PostPosted: Fri Nov 01, 2013 8:58 am Up
Trade Rating: +13
I did it without. But tbh it is easier by removing the bumper. Clips are really fiddly without removing the bumper.
2005 1.4 16v Sport
Check out my 206 here!
DanT
PostPosted: Sat Nov 02, 2013 5:14 am Up
I'd agree with this, definitely easier to remove the bumper although not necessary. For the sake of a few bolts i'd just take it off, can get it sitting perfectly in the cutout then.
