Posted: Sat Nov 02, 2013 11:50 am |
Had this problem for a while now,fitted coilovers and had to fit some spacers and since then i get wheel vibration...the spacers are just plane flat one's they don't have a lip for the wheel to mount on...which is what is needed,i was told by a wheel specialist?..do i need to fit 10 mm spacers (hubcentric) with longer wheel bolts to sort the problem or just fit some longer wheel bolts to make up the 5mm i lost with the spacer's...getting fed up now...any help cheers
Posted: Sat Nov 02, 2013 12:05 pm |
well you answered your question,since the one you fitted is plane flat,that makes the vibration to happen,as the wheel itself is not based on the (hubcentric),which take the load off the bolts :),but for what you have now,all the load is on the bolts,and I don't imagine how you left your old bolts on with spacers on,as you SHOULD use longer bolts,but not too long,make sure to calculate it.,and your problem will be SOLVED
Posted: Sat Nov 02, 2013 12:39 pm |
Many thanks for your help,i will find some 10mm spacer's hubcentric with longer bolts and will hopefully sort the problem cheers Deano:)
Posted: Sat Nov 02, 2013 12:41 pm |
You are most welcome ,it will solve it
