Online Now [849]:
Visitors: 848
Today: 98608
Total: 152501002
Forums › The Car › 206 Problems › Engine noises
Engine noises
ch4c4
PostPosted: Sun Nov 03, 2013 10:53 am Up
Hi all.
I'm having some weird noises from my engine.
When car is cold and i start it there's no noise, but after it gets warm i start getting some rattle knocking sound when i rev it up.
Ive uploaded a video so you guys can hear.
I recentely had cam belt timing belt and water pump changed.
Here is link www.youtube.com/watch?...e=youtu.be
206gti_chris
PostPosted: Sun Nov 03, 2013 3:12 pm Up
could be something on the fan belt possibly a pulley, pas pump. alternator ? will require investigation really to rule things out
ch4c4
PostPosted: Sun Nov 03, 2013 3:38 pm Up
If its gonna be that its fine but someone was telling me it could be something in engine some piston thing.
Tomorrow im going to the place where they installed my cambelt and timing belt to check it, hopefully it will be something like that but thanks for the help.
tommyb32
PostPosted: Sun Nov 03, 2013 4:41 pm Up
tappets?
gazza82
PostPosted: Mon Nov 04, 2013 10:42 am Up
What engine?
ch4c4
PostPosted: Mon Nov 04, 2013 6:22 pm Up
So today i went there and after taking timing belt the noise stops, but after checking everything he said he didnt find any bad bearing or anything. So after putting again timing belt noise started again.
After this the guy said its something inside engine some slack on pistons or something, because when you put timing belt on the some part of the engine is in more tension or effort and it makes the noise.
And he also said not to change the oil because the old one has some layer and if im gonna change it that layer is gonna go away and the noise might get worse.
Do you guys think this is right or could it be something else?
ch4c4
PostPosted: Mon Nov 04, 2013 6:35 pm Up
And engine is 1.4
PostPosted: Tue Nov 05, 2013 5:00 am Up
tommyb32 wrote:
tappets?
Yep!
Let them settle after the cam-belt change (oh-yes) for at least 700 miles, and then start adjusting if it doesn't reduce to an 'acceptable' level.
ch4c4
PostPosted: Tue Nov 05, 2013 9:00 am Up
So engine is ok and there's no risk of it going bad? Cause the guy at garage sugested i changed engine and as i dont kniw anything about
mechanic im a bit lost here.
Also can i change oil or is it gonna make it worse like he said?
And how easy / expensive it is to adjust tappets?
