Posted: Fri Nov 01, 2013 3:16 am |
Only had my car a month i love the car because its quite nippy its a 1.6 xsi 55 plate ive had all the bearing done also a complete timing belt kit and washer pump done but cant understand where this wind noise is coming from the only thing i can think is that it could be the bonnet scoops ? Anyone the wiser thanks
Posted: Fri Nov 01, 2013 4:49 am |
It could be i suppose, open your bonnet and see if the pollen filter is there. Also make sure the doors are sealing on the rubbers correctly, its possible the top of the door could be slightly bent or the rubber perished.
Posted: Fri Nov 01, 2013 6:30 am |
Could it be that a rear window is a tad bit open, suppose you have checked the obvious things though.
Threw me off once, someone had not closed it properly, and appeared to be closed.
| 206 2ltr Hdi glx 53 plate | |
Posted: Fri Nov 01, 2013 6:34 am |
From what you are saying it sounds like the noise is coming from the front?
Posted: Fri Nov 01, 2013 8:51 am |
Hi thanks for the replies ive checked the doors all the seals look perfect and the door is aligned the rear windows look ok ie shut properly my friend said it could be the tyres i will check this tommo thanks again
Posted: Fri Nov 01, 2013 8:29 pm |
Tyres don't make wind noise.......
Posted: Sat Nov 02, 2013 10:03 am |
I know now maybe i was cluthing at straws gonna take it to peugeot next week and see what they say then again everytime i go there they wanna put it on a diagnostic test and thats 70 quid before they look at it
Posted: Sat Nov 02, 2013 4:41 pm |
It's an 8 year old car....don't waste your money taking it to Peugeot, just turn your tunes up
Posted: Sat Nov 02, 2013 4:55 pm |
Ha ha i do that all ready i miss my old 205 at least it was reliable
Posted: Tue Nov 05, 2013 5:09 am |
Is your spoiler OK?
Are the rear boot seals definately OK, (and all the rest of them)?
Posted: Tue Nov 05, 2013 10:57 am |
Yeah its all been checked took it to peugeot and they said there's nothing wrong with it and not to worry like i believe them been in touch with my mates mechanic hes gonna have a look on fri so keep fingers x i will update on fri hope all will be ok i dont trust peugeot thanks for the replies
Posted: Tue Nov 05, 2013 11:02 am |
mike230272 wrote: |
Yeah its all been checked took it to peugeot and they said there's nothing wrong with it and not to worry like i believe them been in touch with my mates mechanic hes gonna have a look on fri so keep fingers x i will update on fri hope all will be ok i dont trust peugeot thanks for the replies |
Peugeot wouldn't say there's nothing wrong if there was.
If they found even the smallest problem, they would bend you over and lube you up with the cost of repair. No dealer I know turns down a job where they can make money from it.
Have you been in another 206 and compared the noise? It might just be normal to the rest of us.
