Online Now [398]:
Visitors: 397
Today: 143370
Total: 157021062
Forums › The Car › 206 Problems › Car not turning over
Deano
PostPosted: Tue Nov 05, 2013 6:21 am Up
Just changed engine car was turning other fine but think I had the fuel lines mixed up the one to the injector goin to carb and the carb one goin to injector now I have put them right it's just clicking when I turn the key any ideas plz it's a 02 206 140 thanks
PostPosted: Tue Nov 05, 2013 6:53 am Up
Flat battery?
Steve137
PostPosted: Tue Nov 05, 2013 6:59 am Up
Starter motor? Try tapping the starter motor whilst turning key
DREWDEN
PostPosted: Tue Nov 05, 2013 7:04 am Up
Irrespective of the fuel line mix up, the starter motor should be turning the engine over, the clicking tells me, problem with the battery side of things, or the starter motor solenoid not engaging.
206 2ltr Hdi glx 53 plate
PostPosted: Tue Nov 05, 2013 12:25 pm Up
Check the earths, also disconnect all the wiring to the throttle body and reconnect. Doesn't sound like a starter problem.
Deano
PostPosted: Tue Nov 05, 2013 2:16 pm Up
What it was fuel had got in manifold and a little bit had gone in pot 4 so empird petrol out of manifold and dried it all up out of pot 4 put it all back together fuel lines the right way round and bingo car started buzzin thank u for help guys
leigh_boy
PostPosted: Fri Nov 15, 2013 9:18 am Up
if you have flooded the motor, you can take the spark plugs out, and then turn the key for 30 secs to clear it, then put the plugs back in and your sorted.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
