Latest: Worthy967
Overall: 17143
Online Now [330]:
Visitors: 329
Today: 108247
Total: 115752451
Forums › The Car › 206 Problems › gti180 not starting!
Go to page Previous  1, 2
markwhittington9
PostPosted: Tue Nov 05, 2013 5:42 pm Up
i really dont think it's done the head everything seems not that bad, its literally trying to start it's so close! pretty sure i bought on about 52k, had a cambelt and 2 clutches since then!
206 gti 180
JamieM
PostPosted: Wed Nov 06, 2013 4:14 am Up
Hopefully it isn't the head then Smile
I'm not sure if I'd keep trying to start it though incase it is the belt and it ends up causing more damage but I'm not a mechanic.
Yeh think you picked it up on around 55k I part x'd it at gates on 54, well I hope you can get it sorted mate good luck!
Aegean Blue 206 GTi180
Schumi
PostPosted: Fri Nov 08, 2013 2:01 pm Up
Can you write your compression readings with full throttle?
2005 206 RC RED
markwhittington9
PostPosted: Fri Nov 08, 2013 2:14 pm Up
They were all 165psi and above, not on full throttle and with a dieing battery! (I just wanted to make sure no cylinders were on 0!!)
206 gti 180
PostPosted: Fri Nov 08, 2013 2:43 pm Up
Sounds like the timing is out. Might be worth taking the belt cover off and physically checking.
markwhittington9
PostPosted: Fri Nov 08, 2013 3:01 pm Up
I am, it's a job for Sunday Sad got Cambelt kit and water pump today! Defo not looking forward to it though!
206 gti 180
markwhittington9
PostPosted: Wed Nov 13, 2013 8:42 am Up
So due to time and weather etc etc the belt still isn't off! It looks like the timing is out as I can't make the exhaust and inlet cam timing ion holes match up (turning engine over by hand) I've read several stories about bent and damaged valves on these engines, anyone know what the compression should be? Mine read 165psi plus on each cylinder with a dieing battery! Fingers crossed this mean no bent valves or is that low?!
206 gti 180
leigh_boy
PostPosted: Fri Nov 15, 2013 2:25 pm Up
165 is not bad really if the timeing is out, i wouldnt expect you to have damaged anythign if its only 2 or 3 teeth out. if there is no matalic noises that is.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Page 2 of 2
