Latest: dreyfalon
Overall: 17121
Online Now [379]:
Visitors: 378
Today: 48476
Total: 97452223
Forums › The Car › 206 Problems › 2002 bsi change
2002 bsi change
ste4332
PostPosted: Tue Nov 12, 2013 12:57 pm Up
Hi I have a problem with my bsi I have seen a kit which includes bsi ecu and remote key is this all I need? or does anything need reprogramming? Thanks Ste.
wwdean
PostPosted: Tue Nov 12, 2013 3:55 pm Up
just make sure the numbers of your bsi / ecu match the numbers on the kit you intend to buy otherwise the car will not start
ste4332
PostPosted: Wed Nov 13, 2013 11:28 am Up
Hi thanks for the info what numbers do I need to check Thanks Ste
PostPosted: Wed Nov 13, 2013 12:36 pm Up
Make sure it comes from a car with the same engine as yours as they are mapped differently, and also try and get one with similar or lower mileage as the display will show the higher value stored in the dash/BSI.
Use PP2000 to record your current parameters before taking out the old parts out and putting the new ones in, this way you can make sure you get the settings right for things like alternator and gearbox type.
If you have things like auto lights and anti-hijack, make sure these were on the donor car as although the engines may be the same, some options aren't available on the BSI.
You'll also need the VIN and security code from the donor car to make life easier in the future.
ste4332
PostPosted: Tue Nov 26, 2013 9:31 am Up
I have been offered a ecu kit from a 2005. 206 1.1 will this work with my 2002 Thanks Ste
PostPosted: Tue Nov 26, 2013 5:57 pm Up
Probably not. Why on earth you replacing it? Water ingress?
