Posted: Mon Nov 18, 2013 3:39 am |
Hi, Today my 206 1.4 hdi started to make a burring noise. It will pull up the gears no problem with no noise but when I let the throttle off for the car to slow down it makes a burring noise. This noise will disappear when I push in the clutch. As it only makes this noise when driving I cant pin point where the noise is coming from. Any help would be great.
| haggis120 206 1.4 Hdi, 2002 | |
Posted: Mon Nov 18, 2013 4:23 am |
Clutch related problem then. Could be the release bearing.
Posted: Tue Nov 19, 2013 1:49 am |
Mechanic thinks its the Diff in the gearbox and would probably need recon box.:-(
