Posted: Tue Nov 19, 2013 7:46 am |
| danhodson wrote: |
I've managed to fix this issue now, and some how my car sailed through its MOT despite being slightly mangled.
I've now got an issue with my radio asking for the code every single time I start the car, almost as if the permanent live isn't working? |
Good, for future ref what was it exactly and how did you fix it?
Posted: Tue Nov 19, 2013 7:58 pm |
| danhodson wrote: |
Happens when you disconnect the battery! Should be able to get one from a Peugeot garage, or Macca might be able to sort you with one, if you ask nicely
Posted: Wed Nov 20, 2013 11:46 am |
I've got the code, it just asks for it every single time I start the car!
Posted: Wed Nov 20, 2013 11:56 am |
Have you had an after market HU in the car? Sounds like it's the red/yellow wire in reverse, either that or the fuse has been moved and not put back in the right place.
www.206info.co.uk/Foru...c/t=16054/
Posted: Wed Nov 20, 2013 1:17 pm |
What would I do without you guys haha! I took the fuse out and put it back in the wrong place!
Posted: Wed Nov 20, 2013 2:54 pm |
| V9977 wrote: |
| danhodson wrote: |
Good, for future ref what was it exactly and how did you fix it? |
Turned out to be an issue with the indicator loom being damaged and possibly shorting out on the chassis!
Posted: Wed Nov 20, 2013 3:06 pm |
| danhodson wrote: |
| V9977 wrote: |
| danhodson wrote: |
Turned out to be an issue with the indicator loom being damaged and possibly shorting out on the chassis! |
Oooh, Macca was right then!
I still think it was the bulb though..
Posted: Wed Nov 20, 2013 3:50 pm |
| V9977 wrote: |
| danhodson wrote: |
| V9977 wrote: |
| danhodson wrote: |
I still think it was the bulb though..  |
And people say this site isn't helpful anymore
Glad it's all sorted. sometimes it helps to think outside the box.
