Latest: sparrowdclxvi
Overall: 17139
Online Now [109]:
Visitors: 108
Today: 33338
Total: 112995217
Forums › The Car › 206 Problems › Water in car
Water in car
gpvecchi
PostPosted: Sun Nov 24, 2013 9:22 am Up
Hi, with the first rainy days in Italy, I found that my car fills up with water; I was ashtonished not to find fishes in all that water!
In particular, I got it in trunk and A LOT (1 or 2 litres) under rear seats.
Is someone experienced in this?
Thanks!
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
DanT
PostPosted: Sun Nov 24, 2013 12:31 pm Up
Not experienced it on my 206 but i'd check the boot and rear window rubbers first if i were you for signs of perishing or poor fitment.
PugJH
PostPosted: Sun Nov 24, 2013 4:27 pm Up
Did you notice if the roof liner was wet?
Depending on where the aerial is check that is well sealed.
But as above it's more than likely the boot rubber.
WIP: Black 1.6 16v XSi
Beauté Noire
pug206lx
PostPosted: Sun Nov 24, 2013 5:38 pm Up
check the seals on the rear lights as well
AndrewR2211
PostPosted: Sun Nov 24, 2013 8:27 pm Up
Did you drive through any rivers lately, in all seriousness though, i used to get water gathering in the foot well of my first car and that turned out to be a rubber grommet missing from under the car, also as stated by PugJH the Aerial seal can be an issue aswell, depends if your aerial is at the front or back of coarse, or if you have a sunroof then check all the seals, apart from that i cant see it being much more else?
My 206 Sport
gpvecchi
PostPosted: Mon Nov 25, 2013 3:33 pm Up
Thank you everybody (in particular pug206lx)! After a check it seems that water comes inside from the rear right tail light...
If you notice, all the water (a lot) coming down from roof along the boot gasket goes exactly over tail light. I reinforced the light gasket and add another on that black flap (that probably was engineered for that purpose, but that was unuseful without a gasket).
Checking in the next days, I'll report back soon!
P.S.: my car now smells like a wet dog...
