Posted: Wed Nov 27, 2013 12:47 pm |
Does it matter which way round the bolts go in on the Shock absorbers for my 2005 206 1.4HDI?
ie Nuts on the inside or outside?
Posted: Wed Nov 27, 2013 12:58 pm |
Rear? For the top the bolt head goes on the outside, at the bottom the bolt head goes on the inside.
Posted: Wed Nov 27, 2013 1:09 pm |
Thanks Edward, I wondered why it came loose after changing the axle!
Posted: Thu Nov 28, 2013 1:55 am |
| Edward wrote: |
| Rear? For the top the bolt head goes on the outside, at the bottom the bolt head goes on the inside. |
I bet this is from memory.
Posted: Thu Nov 28, 2013 2:21 am |
It is actually. I double checked with my photos too!
I doubt it really makes a difference though. They are probably inserted a certain way as it's easier in production. Getting the top bolt in from the outside with the wheel still in place can be difficult though.
Posted: Thu Nov 28, 2013 11:59 am |
It really won't make a difference, just whatever is easier for you to work on.
